- In the wind
OK, will do. Thanks!
ya, you could. the ground could just be bad too.If the eBox is grounded through the stator, could I have a bad stator? This isn't the one that was in the ski previously.
Will the stator and electrics from a 6m6 work With a 61x?
Thanks! I'm told the cdi is one with a higher limit so it sounds promisingYes, but as John said above, you will need to change the cdi or you will be hitting the lower rev limit of the 650.
