It does but I just added strengh with the fiberglass. The foam on these things always gets wet and adds weight so by taking it out you are taking off some weight in the back of the ski.Why did you leave the foam out?? Doesnt that add strength to the bottom of the hull??
I dont think it was as strong as it was before with the foam but it is strong enough I think. You could foam just the bottom like you said. I just dont like the idea of doing all the work tearing it apart to defoam and refoam it and then the foam gets wet and heavy in a year or two. With you having a 750sx you should be trying to cut as much weight out as you can.would you put ny other foam back in or just fiberglass a layer and let it be? Im thinking about doing this on my 750 sx but was concerned about the foot tray. Maybe ill pour some foam down the center only??
Good work on the ski btw, looks good!!
