F
Freestyleriverrat
Guest
I made some adjustments in that section so it should be more comprehensive now as far as terminology. Good link.....nice addition to the cylinder explination
What you need to know about the differences between your cylinder of choice
650 vs the 701's
In short, the 6m6 cylinder has different ports than the 61x or 62t therefore you will have to factor in a different exhaust manifold or complete system into your build budget. Often times if you buy a complete motor the factory exhaust will be included or you can by this seperatly for very cheap.
You can Port the 6m6 Exhaust to match the 61x (dont know about the 62t or 64x) by dremmeling (thx Mouthfulloflake) the exhaust with a carbide bit, they use the same gasket oddly enough...
Ps. awsome info RR thx!
Some young go-getter looking to make a name for himself on the X should finish this thread.
I don't understand this. Is the original poster referring to the stock manifold? ATS_Scott and I have run the 650 Factory B-pipe on 701 61x and 701 62T cylinders. I put a Wet Jet 61X manifold/pipe on a 6M6 cylinder last summer too.In short, the 6m6 cylinder has different ports than the 61x or 62t therefore you will have to factor in a different exhaust manifold or complete system into your build budget.
