I then moved on to the cooling system, because I installed dual cooling and I'm running in 50 something degree water the engine was never getting warm. I used small ball valves to control the water flowing though the dry pipe jackets and out of the head to the pisser. In addition to this I tapped into the water flow (pre exhaust manifold) and routed it to my water box for less sound (with ball valve).
I'm also experimenting on where to place the gopro, I had it on my had pole and the video is shaky but you can tell this think is starting to rip! The powerband hits right away and goes all the way to rev limit.
After making changes to my cooling system I used an inferred thermometer to check exhaust and engine temps. My engine was anywhere from high 130's to 158 depending on where I shot with the thermometer. The dry exhaust was much hotter (as planned with ball valves) in the 180 degree range. It seems as though things are really starting to come together.
