Mods for this season are as follows, modded stock intake and with an adapter plate from Zig mounted a 44SBN and a set of reed boosters. Ditched the jetworks battery and the stock waterbox, installed a Bad bones resonator in the front of the tank and a Coffman resonator Compliments of Mad Scientist in the long rubber tube, installed rear exhaust.I put in a Deka etx9 battery to replace the Jetworks.
Today I lopped 2.5" off the hull with an angle cut and glassed it back up, then I stuck the ride plate up to the hull, marked it and cut it off flush with the hull and did a new D cut on it. I have a 180lbs compression head on the way here, should have it by the weekend .
The next mod is going to be front sponsons, repainting and returfing, I should have the sponsons done by the Smith lake freeride.Glass and paint work on the rear of the ski will be done by the weekend.As it stands now I am in the 270-275 lb range on this ski.
