650TS Steering Cable SBT/WSM or used OEM?
bird
walking on water
I'm looking at replacing my steering cable on my crusty trusty TS. Wondering if anyone has had issues with the SBT/WSM Steering cables?
It's not about the price. It's about the time it takes to replace the part and reliability.
Thank you
If you have access to OEM that's the way I would go, I have used WSM before and I did have to replace one of those twice.
Roseand
The Weaponizer
Wisconsin
Do they not make the oem part anymore?
If you have an old one to send in for reference, push/pull can make you an oem quality one.
bird
walking on water
I went with a JSP Steering Cable.
Attempting to remove the old cable, the Kawasaki TS pump area doesn't have enough room to fit a 27mm Spanner with the pump installed. Thanks Kawasaki, typical Japanese engineering! Only need 2mm more to fit a spanner in there. The Hull is in the way. Maybe drill the hole 2mm lower next time?
Ordered this 27mm Super Deep socket off the Zon for $15. I do NOT want to pull the pump since 650 tunnels need the pump/shoe siliconed in. On my SXR the pump area has enough room to get a crescent wrench in there!
Super Duper Deep 27mm socket
