What's a safe temperature range on the head?Sorry for so many posts but also keep in mind too much cooling can cause issues. I try to remeber to suggest that all my customers run a temp label on the head. If your running an o ring head with added compression and your head temp isn't at least 110 120 Def F your cylinder is too cold. (Don't forget to check as soon as you stop from a hard run as temp will actually go up for a few minutes after cooling water stops flowing). I control cylinder temp with adjustable pisser. There are other ways though.
Chuck Palmucci
CPT Enterprise LLC
609 510 3062
