Vumad
Super Hero, with a cape!
- St. Pete, FL
I don't think jetmaniac rebuilds cranks. His ads for his complete motors say he uses sbt cranks.
It's important to have realistic expectations about your crank. 3-4 seasons on a sbt crank is reasonable. A hot rods crank is $600 and oem is $800, while sbt is $200. If you plan to replace a sbt crank every 2 years or 200 hours, you have to get 6 years 600 hours out of hot rods or 8 years 800 hours on an oem crank.
My 2004 needed a new crank in 2013, 9 years, (unknown hours, first owner didn't ride a lot). I got the crank after I stuck a piston, and the mechanic said the cause of the seizure was due to a case leak (leak down before tear down).
I'm hoping to get 2 years or 200 hours out of my sbt crank. I'm at 8 months 50 hours on a full limited, and depending on how things go (water ingestion, how much is wot, etc). I'll probably push it to 4 years 200 hours. Only time will tell, but I don't see how a used oem crank that came from a 10 year old ski is all that great of an option.
