701 w/OEM 155mm Pump Prop Pitch Suggestions
clouse22
BDB Kustomz
Lake Orion, MI
Just picked up a SF Circus. Planning on building a backup ski / casual lake ripper. Going to run an OEM 155 since the hull is setup for it. Any ideas on where to start with prop pitch & nozzle bore??
Thanks!
Bobby
6-10 skat 3mm cutback
89 or 90mm bored nozzle
Is what impros recommended for me.
I’m building a FR2 with a 155 oem, Ported 760 with a b pipe and head
Fully ported 760, zeel, b pipe. Reduction nozzle 90.5mm. I don't remember steering nozzle bore. Glass tigercraft v2x
Skat 6/10 E-75 155 swirl
Cut 5mm
I have a 701 that I ported with the yamanube templates, oem 155 pump with a coffman sizzler, 46mm wetjet carb/intake with a stock raider 86mm nozzle in a circus and impros recommended a 5/9. Seems to work fairly well right now. I don`t think you would be wrong going with a 5/9 especially if its not ported.
Sanoman
AbouttoKrash
NE Tenn
You know, the Yellow Circus, then the other circus he sold
Thanks!
Bobby
I think the 5/9 is a good place to start.l need to look up my notes (it’s 6am in beautiful NE Tenn right now,too early) and if l am correct an 88-89 mm bore in the nozzle.Running a ss865 pv.The ski didn’t have a lot of thrust at low speed,but came on low-mid for power.But l didn’t keep it a long time to change parts to make it hit harder.lt was a build for Sportfish.The circus that Cory bought had a 155 Scat Mag when l sold it @Big Kahuna
With some effort @clouse22 l believe you can make it hit a lot harder.Let me know what you do!
clouse22
BDB Kustomz
Lake Orion, MI
Will do...will probably start a build thread for documentation once I get my hands on a powerplant! Need to get rid of some other stuff before I move forward
Christian_83
Xscream
Denmark
My buddy ran a OPEM 155 with PFP and dual 44 mikunis on a 701, with a OEM impeller from a wave blaster 2. bored red. nozzle at 88 i think. Worked really really well. its 11/16
CT
I’m running the same setup! What prop you decide to go with?
