- Canada
Is the check valve you were talking about?Ok I’ll try this and let you know what happens
I pulled it off the tank and knew threw the hose and air goes in and out also sounds like something is broken inside of it there’s a rattle in it I don’t know if that’s normal or notThat little white disc looking one is the check valve...
Where can I get a new check valve online Im in Canada btwNo that is not normal. Air should only be able to go through the check valve into the tank not the other direction. Sounds like you need a new check valve
