SX/SXi/SXi Pro 750 Factory Pipe Mani Different From 800 SXR Mani?
JGringo
When in doubt, Throttle-out.
Hey X members,
I recently ordered a Factory B Pipe Manifold for my Kawasaki SXI Pro from Blowsion to accomodate a broken manifold for the Ltd. Factory Pipe. Blowsion states on their site that the manifold works for BOTH the 750 and 800 Kawasaki skiis...
The manifold showed up and we noticed immidiately that the bolt pattern that mates with the head pipe was positioned differently than the original manifold...
I continued to install the manifold thinking that the slight degree change of the head pipe would still work. It turns out that this is not the case...
:smileeek:
The head pipe is approximately 30 degrees outward from its correct position and in no way will mate up to the expansion chamber. Is this Blowsion's fault, or did I order a manifold that was incorrect for my ski?
Again, This is for a Limited Factory Pipe for a Kawasaki 750 SXI Pro. I have the whole pipe system but sheared off the mating face of the Manifold and need a new manifold. Blowsion clearly states that this manifold will work...
Has anyone else had this issue?
-Gringo
P.S. I should be riding at 6 am tomorrow but now I can't. Thanks Blowsion. :damnit:
JGringo
