750sx BACK IN THE GAME! Carb problems...
Hey guys! after years of being away i'm back in the stand up game!
FInally found another stand up to poke around on. Its a 93 750sx. Sat in a barn for 10 years, Removed carb. cleaned every fuel passage. new diaphrams/gaskets.
She will not start after sitting for a while, 3-4 hours at least.
IF you cover the inlet with your hand totally it will fire up, and if you dont let it idle for tooooo long she will run. and when it runs its perfect.
SO FAR.
I have made a block off plate for the stock water drain things, and a block off plate for oil. (running at 40:1 pre mix now)
IF i turn out my Low speed fuel screw 3 turns it will run better, but then it loads up at 1/8 throttle
what am i missing?
Comp: 145.145.
Stock everything.
BR8ES
Fresh Fuel
Pop off pressure is 25.
Even took a torch tip cleaner to the 3 other holes at the throttle plate since they were clogged up.
Hope to see some of you guys out in the cleveland/norther ohio area!
How would you test a carb besides doing pop off? I found that if I stuck a different 38 carb on there it works perfectly. So now we know it's in the carb that came on the ski.
For reference, the carb does pump fuel. Pop off was set. The new diaphragm on the jet side should be pumping fuel into the pilot circuit at idle. And it's not
Vumad
Super Hero, with a cape!
St. Pete, FL
That and make sure the fuel pumps arent leaking.
Magyar68
Really!!!
Lewisville
And when I crank with no start plugs are dry.
Is your Pulse line in good shape? And does your tank hold pressure? Are there any cracks in your Fuel Pickups? may have to take a look closer into the Fuel Pump, or the Fuel Delivery Circuits.
Pulse line is good, pressure tested it. Fuel tank holts psi, and the vent works. fuel pickups check out.
I was able to borrow another stock 750 carb to test on mine, and it works flawlessly. so i know its the carb.
so. what could be wrong in the carb that wouldnt let it idle
Magyar68
Really!!!
Lewisville
The plunger arm adjusted Correctly? Vacuum across the Venturi is supposed to draw the Diaphragm in and depress the Needle arm(plunger arm) If set to low the Diaphragm will not depress the arm. Covering the Opening to the carb causes your Vacuum to go way up and draw the Diaphragm in further than it would go normally. Other wise its in the fuel circuits, and I guess you would have to soak it in Carb cleaner for an extended amount of time.
99,9
SO FAR.
what am i missing?
Comp: 145.145.
Stock everything.
BR8ES
Fresh Fuel
9999999999,9999999999,,of also not a, an animal like that and it would
