detroit
Where in Michigan do you live? I am in Canton and ride at Whitmore lake. Sweet build by the way. Im always on the fence about pulling the 750 out and doing an 1100 in our 750sx. With that 148 pump yours will really pull!!
I live in Three Rivers, MI. Still gotta weld two slugs on the pump to mount the intake grate. I was on the fence also but said what the hell. The 148 pump fits great with the Pro Watercraft shoe, just got some more work to do to get it 100%.
Intake Grate Mount done, cut an old 750 pump up to steal the bracket from it. I did have to do some reshaping for the larger radius. I cut up a broken grate to use as the fixture for positioning.
curious , u left the pump tunnel and only modified to accept the 148 pump ? with the new threads/inserts u placed by aligning the shaft ? and then with pump shoe ?
will the pump be set back further ?
Yes only modified the pump tunnel by filling the area when the shaft comes thru, replacing the pump shoe. I turned the 148mm pump down a little in the lathe to fit. I cut the intake grate bracket off the old pump and tig welded it on the new pump. I used the old intake grate as the fixture to weld it in place. Working on custom ride plate right now.
dfw
You will probably get more cavitation at low speeds, it may be okay once your moving in smooth water. Just like a 550 with a 750 pump or an FX1 with a larger pump.
dfw
Its mostly the inlet pressure drop at low speeds. The effect is trying to suck more water through a small straw. Water boils at atmospheric so we need as much inlet flow as possible.
just curious, why did u not cut the pump tunnel out of doner ski and just drop that in with the pump ?
Just looking at different options for an upcoming project
So it has been a while but have some updates to share. I have been working on making a custom pipe for this thing. Want to move it to the front of the motor to move weight around. Just got the flange I designed in the mail so I can keep going now. It will have a water jacket added to keep the heat manageable.
