Continueing on with the process of completely ruining a good ski...I decided to shorten the handlepole. I got my inspiration from c_legaspi on pwctoday who had a pretty good solution for shortening a stock kawi handlepole but the process for an aluminum pole was much different.
Here's what I have so far. The subplate has a funky angle in it so just moving it with extensions was out of the question. Went to Lowes and got some square zinc plated steel tubing. Then cut it to fit and drilled up the pole to attach it. I used some carriage bolts so they wouldn't stick out too far above the pole.
Now that the mount is in place, time to chop the subplate because it doesn't fit otherwise and just hits the side of the pole.
Subplate installed...
And the final for now...You can see all the places I didn't get paint when I painted the pole.
The problem I've run into now is that the handlebars hit the side of the pole. I'm thinking the pole has to be cut now. The end of the pole also needs to be cut some too but I've gotta figure out how to cut it and then reinforce/replace the frame that got taken out. I'm a little hesitant to do that so I'm going to think about it for a couple days and see if I can come up with a better solution.
PS - The handlebars are now exactly 4" shorter than they were. If I end up needing less, I'll adjust it a bit.
