stumpy622
montani semper liberi
- Hampstead, MD
I'm reinstalling the jet pump on my 94 sx, and can't seem to get it aligned properly. With all 4 pump bolts hand tight the impeller and shaft spin perfectly. I can tighten the back 2 bolts and everything still spins good, the problem shows up once i torque down the front 2 bolts. There seems to be a slight impeller catch as I spin the driveshaft.
I assume the easiest way is to shim between the hull and the pump (front bolts). This is the first time I've torn a pump apart on a ski and certainly wish I would have paid closer attention when removing from the boat in the first place. Just wanted to see if anyone has any advice or tips on how to get everything aligned the easiest. Everything is stock.
Thanks for the help!
