SX/SXi/SXi Pro 750sx/sxi parts
Hi guys,
I have a few parts I am selling from my 1995 750sx, make decent offers!
I have a pump/steering nozzle/stock impeller/pump cone/driveshaft with mount- only problem is pump has a few scrapes (maybe from bad impeller or rock?) but impeller only scrapes them when being put on initially then doesnt once on... so should be fine
Also have side pads/bumpers/fire extinguisher grab things from the rear of the ski...
Also have some engine parts but no idea on worth...if its not much ill keep them... but they are crank with rods (needs new center bearing), good crank case, cylinder (needs bore, currently sleeved at 1mm), wiseco 1mm pistons, stator cover (no stator..), also have bedplate
I can text pictures to anyone interested so let me know!:dance:
do you still have the driveshaft bearing, through hull bearing? whatever its called. If its in good shape Ill consider buying it. I need to pull the motor out tonight to check mine but I'm pretty sure mines toast.
