Super Jet 760 jetting advice
hey I was wondering what you guys would suggest as a good jetting starting point for my ski? its a 62t/62t bored out to a 760, ported case, freestyle ported cylinders, pump gas milled head, b-pipe, carbon tech reeds, f/a's, running stock dual 38's. let me know what you guys think. -Jesse
OEM 38s with crossover open: 75p 135m 1.5 n/s 115g spring with a coil our two clipped off to make 47 to 49psi pop, screws: L 1.25 turns out H .75 to 1 turn out. That's with stock f/a, may have to drop a few psi on pop if using open element filters
that's about what I could find after days of searching lol. thanks for the help!
just an update for anybody running a similar setup this is where Im at(started much richer), 75p, 135m, 2.0n&s, 115g spring (32psi popoff), screws= L: 1 to 1-1/8, H: 1 to1-1/8. there is a slight hesitation at idle to wot (going to try 95g springs for 25psi popoff), 1/4 throttle to wot is almost spot on, lower popoff will make it perfect. hope that helps somebody!
