760 with 35 cc domes
crammit442
makin' legs
here
You can run 50/50 of race gas and pump super unleaded on 35 cc domes. Just make sure you don't have a stock cdi, you need at least an MSD Enhancer cdi set with std timing mark on the stator plate.
I'm assuming this is for performance and not safety. If this chart is accurate, the stock CDI would be safer on iffy gas.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
after 6000 rpm enhancer and stock CDI are looking the same according to that chart?
either way... im not interested in doing anything that is un-pumpgassable.
I am simply too lazy to purchase, stock, store, and deal with stuff I cant pump at EZ-mart.
760
here are my jetting specs
Duall SBN 44mm on 760 ported, ada girdled head 31cc ( high altitude ) 33cc for seal level , b-pipe, pump gas
Main 135
Pilot 122.5
1,5 N/S
80 g spring
+- 38 pop
High Screw +-1
Low screw +-1
#ZERO
Beach Bum
Florida - U.S.A.
The MSD enhancer only has a 3-degree retard rate and I've heard that it varies from box to box.
If you're going to be running more compression an Advent ignition would be the better choice.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
I opened up my oem44 carbs last night
pilot 115
main ( 130 front, 132.5 rear)
1.5 N/S
shiny spring.
I guess Ill be ordering some jets
Main 135
Pilot 122.5
1,5 N/S
80 g spring
+- 38 pop
High Screw +-1
Low screw +-1
hhh
thanks Rags.
I have the combustion dome rings, and the long outter ring, I only need the 2 smallest ones that seal around the spark plug.
i could probably measure those if you need a size? im not sure if it came stated in the kit, but i will look when i get home tonight if you need it?
Mouthfulloflake
ISJWTA member #2
NW Arkansas
if you will measure the rings you have, I will measure the grooves that I have.
IM not sure about how to factor in stretch and contorion, since they go from round to square when mated together?
mainly, id just like to get the numbers together, and accurate to go into the faq, its been very helpful for me lately ording small bits, I would like to contribue!
OMG it has been raining for a week straight but Friday finally will be the day to take the 760 for the first spin....I am so exited...and scared too loool...
This has been my biggest and most expensive engine built so far ! :arms:
Mouthfulloflake
ISJWTA member #2
NW Arkansas
mine too!
and ive shelved it until winter, since im too lazy to even swap pipes or heads on my junk thats running now.
actually, I just dont have time.
IM waiting to hear how yours runs though, remember, you have to motivate me.
even if it sucks, LIE to me...
