300/440/550 85 js 440 to 650 Conversion
Can someone post that wiring diagram again? Trying to figure out the electronic for a 650 swap into a 440 ebox
Yeah what he said, the photo bucket link isnt active anymore.
Im running a 440 cdi/coil and 440 stop switch with a 650 stator (5 wire) and 650 regulator. I Have no spark after connecting based on stuff i found.
got the 4 wire cdi connected as follows:
black/white cdi -> black/white stop switch.
green wire and purple wire from cdi spliced together -> black/red wire coming from stator.
Black wire grounded.
stator is wired as follows:
Both yellows -> both yellows on regulator
black -> Black on regulator
black/yellow -> Black/yellow on regulator
Black/Red -> purple wire and green wire (spliced together) on CDI (I'm guessing this is where my problem is. only wired like this based on forum research. seems weird)
Hello there, I`m new here and I know these posts are from 2012 but I`m doing a conversion too and need some help with mine (I`m new to the PWC world), I`ve rode and raced Motorcross, Three Wheelers, Desert, done all my own work and fab. work... but I`m building a 1988 Kawaski js550 and trasnsplanting a Yamaha 650 botomend with a 701 topend on it, I`m also putting a 650 pump in it but I have the hull, Motor (not in it nor the pump), I just need some help getting started as to where I`m going, can anybody help me please.....
O-side
https://www.rhaasproducts.com/ProductDetails.asp?ProductCode=550-701conv
