Just bought a modded 90 SN and took it out for the first ride of the season this past weekend. Rode for about 15 min before I realized I was running on one cylinder so we pulled it out of the water. When we got back home we took a look and one of the plug caps was partially disconnected. Reconnected that and checked to make sure I had spark in both cylinders. Spark was good and fuel was moving through the lines, so we cranked it again. It would turn over once then quit.
We pulled the ebox to make sure the heat sensor was disconnected, fuse is good, wiring looks good. Pulled the carb to check the fuel filter and that was clean too. Bypassed the fuel selector switch and ran fuel line straight to the carb, still wouldn't stay running. Any ideas? I'm running out of places to look.
