- Southern CA
Weirdest thing. Looks like I'm intermittently getting spark. It'll crank and immediately fire once and then won't fire again. I've pulled the plugs and I've both seen spark, and not. It's not a fuel problem I'm almost positive because I've primed it and sprayed some thrust into the cylinders. Plugs smell like fuel. I tried a new plug (even though the ones in there are pretty new). Put a newer battery in. Basically all the easy stuff I could do, none of which helped.
I've got a paperweight 701 that seized up, so I'm using it for parts. It's ebox looks like ass, but I stole every piece of electronics out of it and put it in the 650 with the exception of the relay (CDI, regulator, coil). Same problem. It'll fire once, then just crank. Cranks hard, so its not the relay or battery. If I let it sit for 10-15 and try it again, it'll fire once, then nothing.
What's the next logical thing to test and how do I test it?
Thanks
Thanks
