Super Jet 91 Shortened Flatdeck Superjet Project
but did you just measure the exhaust tube and cut 3 inches off? did the back place come off with the tube or did it come off separate?
I measured three inches from the bottom of hull. Cut the 3 . Then cut the cap and moved cap up. Practically flush with where it was cut. Exhaust was out. After everything was put back on and glassed I put exhaust back in and it sticks out a little more inside hull but it should be fine. Pictures I posted show step by step.
Sent from my HTC Glacier using Tapatalk 2
Byeai
"Cheetos-Man"
Melbourne FL
Diggity just drill out the three rivets in the back of exhaust flange and then u gotta take out the the glur that held it in and the the tube come right out
Sent from my SAMSUNG-SGH-I897 using Tapatalk 2
dragginblazer
Do Good Jetski Crew
I shortened one 3" the exact same way and left the exhaust tube full length. Just cut the rubber hose down. I didnt have that hard of a time removing the exhaust tube with the gunwhales still in place.
Byeai
"Cheetos-Man"
Melbourne FL
Shes just has to go over it with bondoglass type stuff from the fiberglass store to smooth it out
Jet Ninja
701 reasons I'd rather be at the lake!
tennessee
so i'm a new mamber and i just wonder what is the point of a flatdeck. i think it looks cool but is there a reason for it besides wieght loss
For me I like the look way better and its def lighter but also the tray is wider. Im going to b getting foot straps soon too.
when i removed my tube i drilled out the rivets then on the inside i took a 2x4 and hit it against the tube with a rubber mallet and it slid right out
Jet Ninja
tennessee
ok cool i think ill learn how to do fiberglass work and make one too i love the way they look. Cant wait to see it finished!
Byeai
"Cheetos-Man"
Melbourne FL
Decided not to cut the nose and rocker it but hunna foam the front and glass over
SW UT
Met a guy last year at the lake I go to who had a 650sx flat deck, asked the same thing. He said it was nice since the tray was so big, so you could put weight down on the ski where ever you wanted for a different approach to controlling it.
Byeai
"Cheetos-Man"
Melbourne FL
Yea she dont have the nose cover so just gunna make one permanant
