- Washington
I have a 92 square nose that has been taking on a bit of water, seems like I can go out and cruise around for about 30 min doing nothing crazy just easy lake riding and when I get back to shore I can run the bilge and get about 20 seconds of good flow which seems like a lot of water for just easy riding. Got the ski back home, found a little rock plugging the hole next to where the discharge line for the stock siphon discharges which I’m guessing wasn’t allowing flow by the siphon to suck out the water. Next I found the lower exhaust boot clamp was complete loose and flopping around, my question is should there be water flow inside the boot that would cause a leak into the hull? I’ve looked online and can’t find a definitive answer.
