JetSkiDood
Wow,The Water is COLD!!!!
- Seattle WA
Thanks for the input tom. After more digging it looks like the venture housing should work as you say. The venture housing is 61X-45332-01-9M and the B1 housing is 61X-45332-00-9M. Close enough for Gov't work!!! Ha! The pump I want to put in is complete from a SN. 4 bolts, Shafts are not the same will need the 28 3/4 in. shaft (SJ is 26 in.). A friend is bringing over the housing and shaft from the venture tonight. We'll see if it is the right length.
