Allistah
Slacker
- Bay Area, CA
Hey all --
I have a 1994 Square Nose SuperJet. I love it. I have some questions for all those that race this boat.
About myself:
Height: 5' 10"
Weight: 230 lbs
Ski info:
Pro-Tec Ride Plate
Jet Dynamics Intake Grate
Rear sponsons
Solar "I" impeller
Blueprinted Jet Pump
Everything else on the body and steering is stock
Engine runs incredible and has all sorts of power that I'm completely fine with. Here is the problem I'm trying to overcome. I get extremely tired after about 1 lap on this boat. Outside of just working out more, which I am doing to help from that angle, I want to know what else I can do to help this thing turn better. I feel like I'm putting all of my effort into getting this thing to turn without sliding out. Since I'm a heavier guy, racing with a full tank of gas seems to help it handle better and keep the nose down. A lot of the times I will use my shin to push down the sides of the tray to force the boat to dig in deeper on the inside edges.
Some people have suggested tubbies, some highly suggest new straight 0* handlbars that are wider (I have broad shoulders), one guy said that he put a bunch of lead under his gas tank and shimmed the intake grate and that made a big difference. Someone suggested a really long Worx ride plate. Not sure how much longer it is versus the Protec but I'll look into it. Another person suggested hull extensions as well.
It seems like there are quite a few SuperJet racers here so I thought I would throw it out there and see what you guys thought about it. I'm racing with people that weight 130-150 pounds so I need to change the configuration of my boat so that I can rail as hard as they do for much longer periods of time.
I know this won't ever be an SXR, but I'm pretty sure I can make some changes that will push it in that direction.
Thanks for any info anyone may have for me!
About myself:
Height: 5' 10"
Weight: 230 lbs
Ski info:
Pro-Tec Ride Plate
Rear sponsons
Solar "I" impeller
