WFO Speedracer
- Alabama
I have doing a lot of these engines lately and I have figured out what we need here,trouble is I have neither the time,resources or equipment to even think of taking on such a project.This engine needs a new cylinder or better yet a new top case half similar to the bottom case half that Breed is doing for the 800 engines.If it had a new top case half or set of cases designed where the intake was put on the other side of the case everything would fall into place.That would allow a 90 degree intake to be made putting the carbs where they need to go.I also think an adapter to use a type 9 exhaust manifold would allow the Power factor pipe to be used with this engine ,a 951 with 180+ lbs of compression,some decent carbs ,an advent ignition setup and a power factor pipe would be a awesome freestyle engine,question is are any of you guys who can make this happen listening,we can only hope.:cool2:
