- Eugene, Oregon
951's in particular do not fare well with water ingestion, usually if you get water in it one time it's time for a top end rebuild.Man, thats a lot of work for sure! Back in the beginning of Ski GP. Several guys tried going the 951 route.
sounded good going in. Boats were fast initially, but many struggled to finish a moto. I was not directly involved with those boats, i was doing tech. So can not say what the issues were? Just know, none I ever saw made it into the top 5. I do see 951 in HX / Sport GP and those seem to stay together. X2 is a very Wet hull inside as you know. No motor like injesting water! Good luck!
P
That a snowmobile engine? Curious on the power output. It looks like it has a lot of transfer area based on how the front of the cylinder by the flywheel end is bulged out for more transfer volume. similar to how the tpe cylinders are built.I have no experience whatsoever with DASA 970's but plenty with Seadoo 951's so I can't say in that respect, as far as the out of the box thing I totally get that aspect of it and I too hope he is successful.
I went with the 787, almost as much HP, way lighter , but here is the engine I really want to see someone put in an X2.
95 hp bone stock 6600 rpm , with big bore 800 mods and porting 162 HP.
1997-2001 Polaris 700 RMK Liberty XC SKS Complete OEM Engine Motor Ass'y | eBay
1997-2000 POLARIS Non-Powervalve 700.www.ebay.com
Yes Polaris smowmow but unlike a like of snowmows it's fairly low RPM around 7000 , 95 HP stock , up to 162 HP with mods.That a snowmobile engine? Curious on the power output. It looks like it has a lot of transfer area based on how the front of the cylinder by the flywheel end is bulged out for more transfer volume. similar to how the tpe cylinders are built.
Are you talking about this 951? It’s 130hp stockYes Polaris smowmow but unlike a like of snowmows it's fairly low RPM around 7000 , 95 HP stock , up to 162 HP with mods.
There are some Skidoo snowmow engines that turn close to 11.000 RPMs.
