Other 96 seadoo gtx
jeremy chambon
Need more power
rockford MI
i have a 96 gtx with 85 psi in both cylinder. so its time for a rebuild and i work at an auto shop so i have the hook up with boring. but im also think putting a different motor in her its 787 motor what other motors will drop right in that are bigger?
I wouldn't say heavy modification, but you would have to fab up a new mount for the front and swap sides with the electrics and exhaust systems, not worth doing really unless you have all the necessary parts just laying around, you are only talking 20HP difference anyway. A 787 can be modded to eat a 951's lunch fairly easily.
More than likely inner crankshaft seals, you can test these by plugging off one large oil line to the rotary valve and pressurizing the other with a popoff pressure gauge.It should hold 5 lbs for 5 minutes.
