- Tuscaloosa, AL
no, you just remove the 4 mounts and push the motor forward a bit.
I once pulled the motor just to replace the dampner.
Actually, I would just remove the 4 bolts that bolt the cradle to the mounts. Both ways work, just twice as many bolts to remove, you would still have to losen the 4 bolts to shim the motor. Twice as much work but same result.What BK was talking about was removing the rubber part (dampner) of the coupler and pushing the motor back so you can line the 2 metal parts of the coupler up perfectly with eachother. This is a good method. You do not need to pull the motor out for this, simply unbolt the motor mounts from the hull (not from the motor) and slide it forward.
Then bolt the motor mounts back in place, and shim between the mounts and the motor until the coupler parts are perfectly aligned. There was a pretty good thread about this not so long ago, I'll see if I can find it..
if you need a new dampner let me know. I believe I have a new one I can let go.
Line up that coupler with a 6" machinest scale.
get 4 new oem from John Highfield at Greater Yamaha,West Palm Beach...why go through all the work to change them w/ used ones that may break soon....
(johnh@greateryamaha.com)
Ride it!
