98' RN Restoration
Very productive day today! Cut tray, de-foamed, sanded, sanded...sanded some more. There are a lot bad patch jobs on this thing...see pictures. Got everything prepped to cut 4 inches off bottom and re-glass back together tomorrow. Everyone says how bad de-foaming is...I kinda enjoyed it lol. Also found out my pump shoe is cracked. :mad: Gotta get a new one.
  • Like
Reactions: Meh
It's official! Shortening is underway...
Heading to Lowes for some pink foam.
Little repair on the back and got a little of the foam in where the void was made from shortening. Will glass that over once I get the end caps put on and fiberglassed in place. I cut it so that I could use the same rideplate bolts inserts. Will use a cut down SN plate.
Bolted up the ride plate with the end caps attached and filled/ glued them in place. Tomorrow I will remove the ride plate, sand a bit, then start putting fiberglass on. Will probably do 2 layers of 1208 biax and a layer of 8.9 oz cloth on outside, then 2 layers of 1708 biax on inside.
Got all the filler/epoxy sanded down and did some fiberglassing! Also found a crack on the side under the bond rail so I fixed it... Next is sand it down after it cures and put some 8.9 oz cloth for a smoother finish. Then reinforce inside with 1708 biax.
I have an extremely clean 62t waveraider engine. Very low hours. So it's gonna be 62t dual pulse case, 62t 701 cylinder, and dual oem 44's. No porting as of now unless I get the courage to port cylinder myself with yamanubes templates lol. Eventually gonna get a ported 760 cylinder from HPE.
Nope. Nothing new lol.
Gonna start up again in about a week.
I though about rockering the front but then decided I wanted to ride it rather than do more fiberglass work.
Yeah I just finished fiberglassing my -4" angle cut and I'm a little sick of glassing now. Buttttt CarterB lives like 20 mins from me so I can get his rocker nose kit local so that's the only reason I'm doing the extra work now.
I'm hoping to finish it by April... but I have limited time to work on it
