This is a 62t / 61x 781 big bore JM motor, with dual 38s, MSD Enhancer, MSD coil, and lightened flywheel, running 188 psi. Ok, long story short. Rode Daytona free ride, and at the end of the ride, noticed a little break up at top end. Got back to shop and flushed out . This Saturday, went to the river to ride, and within 5 minutes, was back on the trailer confused. Took off from the ramp, ski was breaking up and got worse. Then all of a sudden, the ski shut off and would not refire. Took the ski back to the shop and ran a compression test, 188 and 188, so no issue there, even took the head off. Did notice a little fuel leak at the slave carb on the inlet side. Rebuilt carbs, and re installed. Lake test came up with the same result, 5 minutes of breaking up, then shut off with no restart. Did get 1 backfire out of it after letting off the start button. So I have compression, and fuel, so I am starting to lean towards an ignition issue. Any of you engine gurus have an idea on where to start with the ignition issues? The flywheel was off Saturday, and stator looked ok, but looks can't always see the issue. I did do an old fashioned spark test, which is showing a weak intermediate to weak spark at best. Both MSD coil and enhancer are a year old. On a side note, the ski fires up and revs on the trailer, but in the water it breaks up, and after a little heat, shuts off. Ski will fire up when it sits for a while. Any advise or preveious experience with a GREMLIN like this little bastard would be greatly appreciated.
