- central florida
You should clean every connection in that corroded box !!! Also, consider ordering a new gasket.
LOL, gremlin found. And the answer Is? Crappy Chinese starter solenoid. That dirty little bastard.
Never thought about the braided line, great point. I have new lugs for the fix on both cables. Dug out another clean e box, solenoid, and stator. Need to get with you tomorrow for a coil and gasket.That looks like an oem solenoid?
Does the braided sheathing on power cable right under the grommet? That may be one of your leaks if so.
This box was siliconed shut.Get a new ebox seal and line it with grease or silicone before you put her back together.
