yamabro
GP Performance / Patterson Powersports
- Dickson, Tn.
So far I've Ground down the OEM siphon tube and the pisser tube.
Then I put a flat piece of stainless steel on the back side of the open hole to make it easier to hold the melting aluminum as I Tig welded them up and smoothed them down.
Now I'm going to bore it out. It's at 86mm. I was going to bore it out to 88mm.
I'll post pics by this weekend.
Would like a little feed back on some of your preferences out there on what bore do you like best or performs better,... 87mm?, 88.5mm?
