Super Jet Ada 701\760 girdled head fitment issues.
Has anyone else experienced fitment issues with these heads on 62t cylinders. Its like the girdled studs are off. And is throwing the other bolt holes off. I've got it corrected was just curious if anyone else has had the same issue
Sent from my QMV7A using Tapatalk
Yes. That is an issue with the 62t case. You have to machine off the tabs around the top of the cylinders where the interference Is ,So that the studs can drop straight in. I had the same issue on my motor build this past winter. It had me stumped for a little while.
Yeah I did that, I still had an issue afterwards. Only place I didn't remove material was center one exhaust side. Looks like the stud is Up next to the side of the hole pushing head over a bit. I'm not gonna mess with removeing that spot on a fully assembled motor lol
