Trying to figure out if the head is warped or whether my fuel requirements need to be upped. I'm running around 200psi on my speedwerx big bore motor. The sleeves are level with the top of the cylinder and the old Speedwerx head that I had worked good but even straight avgas was pushing the limits of what that head was putting out. So I'm running the ADA head with 93 octane gas now and I blow an o-ring about every week or two. The domes were brand new when I got them but the shell was used. Any ideas what the problem could be?
