Super Jet Adding Spitter to SJ 650
djkorn1
kidkornfilms
Cleveland Ohio
This square 650 has no spitter???? wtf? There are two lines coming out of the back of the ski, is one water intake and one spitter into the pump? or is it dual cooling.
The ski is completely stock except intake, rideplate, impeller, flame arrestor.
oxnard111
Creative RE Purchasing
One is water intake while other is the syphon bilge...
You are correct they did not come with a bypass... You can either tap the cylinder head or there is a plugged fitting on the back inside section of the pipe... kinda near the rubber elbow... you can purchase a flush kit to plug into there put a bypass... Or you can cut the line running from the top of the head into the pipe and put a "t" fitting there also that would lead to a bypass.
SJBrit
Extraordinary Alien
Bradenton, FL
DJ: just go ahead and T off the pipe that goes to the head and run that to a bypass - that's what I did on my 650.
Sent from my T-Mobile myTouch 3G Slide using Tapatalk
djkorn1
kidkornfilms
Cleveland Ohio
The line is like 1/16" thick????? Its SUPER tiny....don't know if I can even get a T that thin...
djkorn1
kidkornfilms
Cleveland Ohio
Aha...found it. Thanks Brit and Boom...it was covered with that plastic wire covering.... so I shouldn't use the flush kit line?
