Super Jet adhesive from stickers
i have just finished removing graphics on 2 90 sn sj, there was plenty of adhesive left underneath--bought turlte wax label & sticker remover at auto parts store---spray it on and allow it to soak and penetrate the adhesive for a minute or two, then scrap it up in wads with scraper or straight razor and wipe it off with rags or paper
i used 3m adhessive remover with a razor blade worked perfect! the only problem i ran into is i live in texas so i did it in 102 degree weather so i had to keep respraying to keep it wet but once i figured that out it came off easy.
OCD Solutions
Rentz, GA
I just discovered lighter fluid works too. I purchased it for another project and was surprised the read that it was an adhesive remover as well. I tried it out on a few different things and it worked awesome.
i just used a 3m stripe off wheel on my truck for adhesive removal and that is the best thing ever. iv spent time with all the chemicals (acetone mek brake cleaner goo gone) and thoes just make a goopy mess the wheel on a drill or air tool pulls that crud off so quick and doesent even jack the paint up
