- Boynton Beach
Just when I thought PHP is the better product, came across this thread. Good info. ADR cranks are POS based on personal experience. Looks like going back to DASA with 8mil crankworks crank.
Lower piston rod bearing on the rear cyl put a hole straight through 8mil stroker cases at 50h. All i have left of my engine is carbs, intake manifold and cylinders on a 2nd bore.Who are claiming the issues is with the ADR cranks itself and not another factor like water, compression or ignition?
@dmpus what happened to your ADR crank?
On the market for a new engine PHP, ET or whatever is out there. I like stroker extra boost on the bottom but i may try SS if it is that good (doubtful tho)
One season. Never sunk. I ride 99% surf so for sure it took some salt through it. Always rinsed at the local lake, always dried and kept with open hood. Always fogged after rides. It did sat for longer periods of time during summer months when surf is flat here so that could be the biggest contributor.How many seasons did that crank have on it? (in whole years)
Are you 100% this didnt happen from hydrolocking or water intrussion that rusted the bearrings?
How do you think nicasil cylinders will hold up in the surf? Drinking salt cocktails is inevitableI’ve had a few adr cranks. 10mil in a tpe 1105 I had bought from skinnyman ran about 300 gallons before the rear bearing went out. I had a 10 mil adr in a Dasa I broke a piston in and a 16mil adr in my tpe 1200 I ran about 300 gallons through. The 16 mil needs a rebuild. Bearing cage started to come apart but I caught it before it did any real damage. So far my 1200 has been the most reliable motor I’ve ever had. No complaints
Nicasil does not like water ingestion just like any other motor. But In most cases what ends up happening is the piston transfers aluminum on to the Nic and the actual bore is left un-harmed. This can easily be cleaned off if one knows what they are doing. Every winter I have sent my cylinder to TPE to have it cleaned and honed. The last time it was done Erik checked the bore with a bore gauge and it measured as good as brand new after 300 gallons.How do you think nicasil cylinders will hold up in the surf? Drinking salt cocktails is inevitable
