so check it out... i went ahead and ordered that set of bars...
looks pretty good i think
i had to go to ace hardware and get some longer stainless metric allen head bolts to make it through the stock mounting bracket
i also had to drill a hole for the pin on the start stop switch and for the stock throttle lever.
still need to file down the left grip area(grip wont slide over the rough metal), cut the bars a bit shorter tomorow... they are soooo wide and adjust my throttle cable... its a bit tight right now.
unfortunately i ran out of daylight so it will have to be done tomorow.
ill take some better pictures tomorow in the daylight once the job is complete...
