Air leak from hell!
when its running and its hot take your air compressor and blow it around were you think you mite have a leak,if you have one the influx of forced air should kill the motor!
High Speed Industries
Your one stop shop for quality parts @highspeedind
I've always noticed that my manifold/reeds get colder after I run the engine. I think it's something to do with the negative air pressure change. Are you sure heating it will replicate the issue?
Quinc
Buy a Superjet
California
Brand new bulb primer and connected to the return line. So far I have gotten as far as removed the exhaust, tank, and removing the 4 bolts holding the engine down. Having a 2 year old running around makes progress fairly slow.
Quinc
Buy a Superjet
California
@Rdrttoy hooked me up with some new oem quality gaskets so everything is fresh with a liberal amount of 1211 and torqued .5lbs over spec. Through in some new ada orings as well just to make sure. If she still doesn't run right I am going to smash it to bits and run the stock 62t out of my loaner couch..
Or you can light it on FIRE!!!
Quinc
Buy a Superjet
California
Well f$#@JK me! She does the same f-ing thing.. Only thing I haven't done is replace the carbs and only extra carbs I have are BJ 48's. Anyone have any jetting suggestions on the BJ48s? I talked to Art and he told me the carbs are for 900+ cc's and he didn't have any jetting recommendations for me.. I have read a few threads with people running them on 701's so figure I will try them anyway.
If no one chimes in I am going to start with:
125P
115M Smallest mains I have are 100's and 115's..
21 Psi (2.0 and black spring)
MN
125P
that's the jetting im currently running on a stock 62t/62t with oem44s and a Bpipe w/ 650 chamber.
MN
It is working rather well besides an occasional stumble when I try wake. my next action is to lower the pop off pressure to 18-19 and then perhaps go down on the pilot jet.
Quinc
Buy a Superjet
California
Good news! Put the BJ'S on with same jetting and 18psi pop off. Just tested with a few high revs and no more issue! Really smokey though so probably need to raise pop off back up a hair.
Now to throw my 44s in some Chem dip.
Thank you everyone for your help!
Quinc
Buy a Superjet
California
She's alive! Jetting ended up being a hair lean and I had to turn the high jet 1 3/4 turns so she wouldn't fall on her face. Was also able to nose in most of my flops. Hoping a 120 main will give me that much more power.
Quinc
Buy a Superjet
California
Woohoo!! brap jacks off the market now?
My plan was/is to sell them and just get some brand new mikuni 46's from amazon. Sometimes they dip down around 190$ each. And with any money left over get the blaster a boyesen intake manifold and reeds.
My plan was/is to sell them and just get some brand new mikuni 46's from amazon. Sometimes they dip down around 190$ each. And with the left over manifold get the blaster a boyesen intake manifold and reeds.
Looks like $199 is the lowest they get.
Ski idles fine and I can blip it to 1/4 throttle or so on the trailer, but a blip to 1/2+ and she takes off like a rocket and I have to give full throttle and hold down the stop switch. While riding when the pump leaves the water she revs high till the pump is back in the water.[/QUOTE]
Load will slow the engine down in water, out of water u might have NS stuck or worn.....u blip and it sticks open ??
Leak down test is best to make sure everything is tight , once that's done u can move on to Carburetor etc...
I do leak down on all engines I build/rebuild, peace of mine and ease of finding troubles afterwards.
