vitalikol
Jetski-Snowboard
- Pennington,NJ
My ski develop air leak, runaway on initial start up. Yamaha motor - where to look first ???
that starting ether trick sounds like a good way to blow yourself up!
I like to use a propane torch to find an air leak. Just take a small propane torch and open it up, DON'T LIGHT IT, and just move it around slowly in some of the areas it might be sucking in air. If there is a leak, it will drop the RPMs down.
i like to use a propane torch to find an air leak. Just take a small propane torch and open it up, don't light it, and just move it around slowly in some of the areas it might be sucking in air. If there is a leak, it will drop the rpms down.
Is it only at "start-up"? Cause you might not have an air leak at all.
Been down this road. Primer or choke?
pm me if you want.
Dan
