- King of Prussia, PA
Probably a stupid question but how are you guys aligning motors in skis where you can't see the couplers? Mirrors?
Thanks
Thanks
Absolutely without the rubber dampener. It will shove the couplers in a better position without being properly alligned.Maybe this is obvious, but do you shim without the rubber widget between couplers? The idea being align and label without that in there applying pressure. Then pull apart, insert the widget, reassemble. Or is that being too picky?
