- Great North West
First step would be to try and get your motor to spin over by hand. Pull plugs, take the black splash cover off (two 10mm bolts at rear of motor) optional. Try to turn over by hand back and forth........... if you get no movement pull four motor mount bolts and exhaust hose and slide motor forward to de-couple from coupler. Now try to turn the motor over by hand, this will rule out the possibility of the jetpump being frozen.
If your motor still will not budge by hand pull the front cover. I have had a motor that would not turn over and it turned out the flywheel was rusted to the stator because of water intrusion. You could check this before moving the motor forward if you wanted to. If both ends of the motor look clean and wont move, work you way into the motor via the head, etc.
You may have electrical issues as well but it takes no time at all to check for a locked up motor /pump. You will know right away if your motor is locked up just reach in and try to turn it.
YES!! get the motor to turn over by hand!! On your 01 sj being that the only ground wire from the motor to the eletrical box is a 16 gauge wire. (This wire is running in the stator loom to the E- box) I have seen this whole loom melt, as one, causing a electical nightmear. This can be caused by excesive current being past through the system and no where to go. like trying to start a locked up motor. never, ever hold the start button down when the motor wont start. And don't keep pushing the button trying to bump it loose. good luck!
