Alternative hood seal
Motorheads5
Livin the generation gap
ketchikan alaska
I am real happy with it so far. x2addict is a good proving ground for this hood seal let's see what he sez after a year of use. I'm not saying he has his hood off alot LMAO
Crab
thanks darin...noswad!
Seattle
Just installed this morning. 2nd one I have done, and like it. Note the small cut piece by the bilge outlett, the trick is to get the hood centered and lock it down overnight. By morning you will have a nice groove formed.
attachment.php
FlightPlanDan
Don'tTrustAfartAfter50
it looks pretty nice, but can it honestly be AS GOOD or better than an OEM superjet seal????
No. It's not made for a yamaha! But you can replace it 5 times b4 you cover the cost of an OEM.
I've replaced the hood seal 2 times in seven years. It still makes good sense to go watcon.
It's not the same and it's not perfect. It's an alternative to the silly OEM price.
FlightPlanDan
There's no denying OEM is the best. It just costs too damn much.
This seal, so far, has kept the water out. That's it's job. It's doing fine so far.
I'll let ya know how long it lasts. Cause that's what it's gonna boil down to.
butti
lone wolf
F-XTC
my good oem seal don't seal at the front.......
running stiff pole? that can make the front of the hood opening sag like the sn's do
if everything is lined up,the ski is not warped from running stiff pole and the seal is installed properly the stock seal will not leak.
