screaming440
The Old Skool Professor
- KC/Lake of The Ozarks
the aluminum 440s were talked about in adifferent post.
anyway here is a pick of one next to a cast iron 550. both are ported and you should be able to see that the transfers on the aluminum 440 are much larger and cut up into the sleeve. also the profile of these is different and they had 2 extra head bolts so they are not hard to spot.
