- Texas
I have a few of these laying around so whoever makes that aluminum hull I can get ya one for a good deal.
I am also a union sheet metal worker....its a good idea but alum is very brittle and the vibration alone would crack the hull...thats why everythin alim is either cast or billet
Nah it could be stamped out and have pretty much the same form as a glass ski, as GSXR Mike describes above your post.You have to keep in mind the hull is gonna be all boxy since it'd be constructed in segments that can't be as exact as fiberglass. The hull will also obviously dent as said above. Which is easier to repair as said, but will look likein no time, and pounding out dents won't ever look the same. If you also dent the hull while you're riding, the hydrodynamics of the hull will be modified. Then there is also the fact the aluminum can't flex. It'd be like riding a car with no suspension, you would feel every little wave and bump, where as fiberglass will flex a little bit and absorb some of the rough feelings of riding.
Disadvantages:
Corrosion pitting and hull degradation is imminent especially in salt water and where steel fasteners are used
You're likely to dent it
