- Denver, ColoRADo
Zach if you could give me a call. I would like to send the cylinders back to you. Just need to know time and cost. They are the two things I am running out of quickly
I did. The instructions with the pistons put the end gaps in a different location and never mentions the alignment pins. I thought they were to lock rings in place. MY bad and I paid the price. I expected to make some mistakes on this build this one is just hard to swallowId like to see better pictures of those cylinder walls and crosshatching.
And how the hell do you get pistons into the hole if the ring gaps arent lined up with the piston pins? You'd have to smash em in.
My question is this. If you say you followed the instructions (which I believe) were the piston instructions not in your possession/provided (every piston I've bought has the intsructions explaining this)? They usually explain ring gap and you had no idea what other posters meant by that term? Good luck next time, and we have all cost ourselves money at one point. Learning costs money unfortunately, but if you weren't provided the info ya paid for, well then.
I want to say my pistons or the rings instructions said to have the ring gaps @ 180 degree's of each other, but of course the pins on the pistons would not allow that.
I know what the ring gap is and to check it on a used piston. My instructions said to put ring gaps at 180deg lined up with wrist pin with no mention of alignment pins. First motor build so I didn't know anything about them. The cylinders will be on their way back to PHP tomorrow and just have to chalk it up to lesson learned. I do aircraft motors and have never seen anything like that and I live by the intructions and maintenance manuals given. We do have a lot tighter tolerances on our ski motors than say an inline opposed aircraft motor. Turbines different story.
Believe me everything will get measured this time
Like what @ WB1994 has been saying, it doesn't make since that you would be able to put the pistons into the cylinders without the rings being lined up. so maybe they where upside down?
I've done it before. But the second you try to turn the motor by hand, you know something is wrong because the cylinder won't move beyond bdcLike what @ WB1994 has been saying, it doesn't make since that you would be able to put the pistons into the cylinders without the rings being lined up. so maybe they where upside down?
