I have been searching constantly but found nothing really on par with this issue/question. I have a limited 701 setup and trying to dial in my pipe properly. All FPP says is that the first couple inches on the chamber are supposed to lightly sizzle. How about the head pipe? My headpipe sizzles quite a bit (mainly at the headbolts). When I add more to top to reduce heat, chamber doesn't sizzle. Not too sure if this is okay or if i need to get more water to the headpipe. I have it set currently at 3/4 turn top and others closed. Cooling lines are set to how FPP suggests w/ a FCV just before the stinger and after the T.
Thanks in advance,
Jeff G.
Thanks in advance,
Jeff G.
