another dual bilge question
where is the best location for the 2 water outlets? both on the port (or left) side or 1 on ea side, the starboard or right side seems tight, definetly above the bond line right?
carbonjet
USA
Not sure about locations but running 2 pumps is a good idea if you plan on doing lots of subs and deep stab surf riding
Sospikey
Trying to get upside down
Sweden
I actually put a "y" in there and use the same outlet for both pumps. Less holes in my boat...
WRX Dave
Freestyle poser
Downside to a single outlet is if one pump fails, some water will backflow through it from the other pump.
Doesn't seem to matter which side you put the second outlet on, but you want to keep the hose as vertical as possible. And yes, above the bondline.
