Id hate to get arrested with you...
Did you read post #56?
I havent seen one of these fake heads other than on here. I would like to know whats wrong with then thats making peoples engines blow up as they are not to hard a thing to make right are you sure thats what is causing the blow ups . I dont like the fact they have used ada,s name on them thats just wrong. If they can do them at that price why dont they just start there own competition business in the head market. Change a few angles and top design a little and away you go.
I have a rough idea what can blow an engine up , thanks for that.Oh don't know incorrect squish angles, incorrect dome sizing, sloppy fit between the domes and the head, thats just a few things I can think of right off the bat that could blow an engine up.
Were these some of the issues with these heads. I mean when you put a head on you should be checking squish and compression if you dont do that then you cant really blame anyone else but your self.
If you put the dome in and it was loose you would stop then not continue putting it together and hope your engine doesnt blow up
Im not defending the people that actually made the heads but to blame them for all the blow ups maybe something they dont deserve either
Yes I think I said that I dont agree with them ripping of the ada head. I think thats not right at all using them name to resell there product and using ada,s product for there gain.Are you serious? It doesnt matter what the "customer" does or doesnt do. They are illegally ripping off the ADA head and selling a product under someone else's name and hard work. So YES I blame them for EVERYTHING!
My point is that there is stuff that should be checked when you install any aftermarket head. If you fitted an ada head and didnt know your cylinder was skimmed previously and you smashed a piston into the head would that be ada,s fault or yours ?? It does matter what the customer does or doesnt do
I believe they should have done it the right way and made up there own label and design and introduced a new product choice to the market. Competition is a great thing.
Personally I would have still gone for an ada I use them on all engines I build for myself or customers
I didnt see where he said that they were I saw him asking the question "This is bad. Besides the illegal use of ada's name, products, and reputation, what is the tolerance for domes, squish, etc."Check out the original thread about these heads. It was linked here somewhere by Jetmaniac.
Some of the problems:
Inferior aluminum
Sloppy fit between domes and head shell
Resulting waterleaks
Inferior material for domes
Inferior material for head shells.
The reason "they" can crank them out for so cheap is precisely because of the materials used and the small amount of time spent on making a product with the right tolerances. Yeah, a customer should be checking squish. But a customer shouldn't have to worry about their head studs rusting away or their chitty fitting domes leaking water into their engine, or even just being sold something that it is not.
I agree with that, thats ficking wrongI don't think the makers of the fake head are interested in starting their own brand or making a quality product. The aim of this whole thing is to capitalize on a well known quality name with a bad product that appears to be ADA and cash in on it. Those are not people I'd buy from nor are they people that would take care of customers.
In other words, this isn't really about heads - it's about ripping people off.
1. Why does the buyer say you claimed purchase from ADA's website?
2. Why did you delete the externally hosted image of the head in the PWCToday thread?
